Who's Online 0 Members, 0 Anonymous, 1 Guest (See full list)
Petr Vanek - Robe started following GDTF and MVR Events at PL&S 2024 , GDTF Builder Update April 2024 and Saving errors
Darren joined the community
Cruze_Volux joined the community
Ambroise joined the community
Hugo Casola joined the community
I'm testing a build fixture Brother_Brother_and_Sons@Compact_Fresnel_Light_-_Wide_-_Single_Color_5600K@REV0.gdtf in MA3. The fixture is Single Color, but on the Color tab the values for R, G and B show up(they don't work). How can I make them disappear, or I did something wrong when I created the fixture?
But is there another way todo it?
