Who's Online 1 Member, 0 Anonymous, 10 Guests (See full list)
Babass joined the community
atdemeo joined the community
ihendrick joined the community
zhekoss joined the community
Petr Vanek - Robe started following GDTF and MVR Events at PL&S 2024
AL6lights joined the community
rolf vom berge joined the community
Mr OnOmE joined the community
dmireles1010 joined the community
michalpiosek joined the community
mueller.ca joined the community
I'm testing a build fixture Brother_Brother_and_Sons@Compact_Fresnel_Light_-_Wide_-_Single_Color_5600K@REV0.gdtf in MA3. The fixture is Single Color, but on the Color tab the values for R, G and B show up(they don't work). How can I make them disappear, or I did something wrong when I created the fixture?
But is there another way todo it?
Yes. Persistent, not DMX related settings can currently be described via DMX modes.
Follow-up question: If I have a setting in my fixture that, when turned "ON," adds 7 channels to all my DMX modes, how can I implement this? Do I need to define DMX modes with this option "ON" and again with this option "OFF" (as shown in the image)?
That is exactly what >I was looking for. Thank you.
Hello, You are looking for Relations: https://gdtf-share.com/help/en/help/gdtf_how_to/key_handle_mode_dependencies.html
Hi, I'm wondering if there is an "IF" function, or something similar for DMX modes and channels. For example: -I have a DMX mode with 3 channels(1-3CH), but depending on the value of 1CH the properties of the next 2 channels change. - 1CH has the value "1" then 2CH has "x" and 3CH has "y" -1CH has the value "2" then 2CH has "m" and 3CH has "n" -1CH has the value "3" then 2CH has "a" and 3CH has "b" ... And so on
