sl1200mk2 Posted November 30, 2024 Posted November 30, 2024 Hi, this file for example Martin_Professional@ELP_PAR@20241107NoMeas.gdtf have 555 permission on some folders. I don't know if it's a usual practice but in my app I decompress .gdtf files, use what I need and then *delete* extracted files/folders. But with 555 permission I'm screwed. Is there's a way for you guys to prevent/modify permissions? for all of files to be at least 755? best regards, nicolas
Petr Vanek - Robe Posted December 2, 2024 Posted December 2, 2024 Hi Nicolas, interesting. I have tested this Martin file and can confirm the issue. As Martin does not utilize the GDTF Builder to create the fixture files, i suggest that you contact them and i am sure they will follow up. Theoretically, we could try to handle this in the GDTF Share, but there are risks associated with changing of the uploaded data. We will discuss it. What i would suggest the most is to unzip with better default permissions, or run something like chmod -R +xrw models on the unzipped files, which then always allows you to remove them later. Cheers Petr
sl1200mk2 Posted December 2, 2024 Author Posted December 2, 2024 Hi Petr, thanks you for your answer. I've adapted the strategy in my software, so now it's painless for me. best regards, Nicolas 1
