Prolights Posted March 21, 2025 Posted March 21, 2025 Hi All, I found a bug in the builder, similar to this one: When you copy a channel function from another page of builder (different GDTF) and paste in after a channel function you already have in a dmx channel all the channel sets phylical values are changed to the physical value of the channel function. If the copy/pasted channel functio hase physical values 0-90, all the channel sets inside this channel function will have 0-90 as for physical from / to, they lose their original physical values ranges. Could you please report this to the developers? Thanks. Best Regards.
Petr Vanek - Robe Posted March 26, 2025 Posted March 26, 2025 Hi @Paolo.Prolights, we were able to replicate the original report, but it seems that this new report is the same as the previous one, or what exactly is the difference?
Prolights Posted March 27, 2025 Author Posted March 27, 2025 Hi @Petr Vanek - Robe, please find the difference following: 1st: the Channel Sets physical values are reset to 0-1 when paste a channel function copied from an attribute with ModeMaster from a different dmx mode of the same GDTF. 2nd: the Channel sets physical values are reset to the channel function physical ranges when paste a channel function copied from an attribute from a different GDTF. Thanks. Best regards. 1
