teclim Posted April 4, 2025 Posted April 4, 2025 I have imported the gdtf of robe parfect 150 fw rgbw in mode 1 (made by the manufacturer) on GrandMa 3 but even if I put red, green, blue and white at full, the color is blue. Does someone have this problem ? And how to solve ? Thanks.
Petr Vanek - Robe Posted April 4, 2025 Posted April 4, 2025 Hello @teclim, at the moment, this is known behavior of the gMA3 visualizer on fixture files which contain real world color measurements. You can eliminating this either by disabling the White Point 8000K in the Robe physical fixture or by unlinking the RGBW Emitters from the RGBW attributes in gMA3. Kind regards Petr
teclim Posted April 4, 2025 Author Posted April 4, 2025 Ok, thanks for replying. Is it the same for T1?
teclim Posted April 4, 2025 Author Posted April 4, 2025 I delete the emitter in the fixturetype in gma3 for t1 but yhe color is yellow instead of white.
Petr Vanek - Robe Posted April 4, 2025 Posted April 4, 2025 4 hours ago, teclim said: Ok, thanks for replying. Is it the same for T1? Only in RGB* modes, in the default CMY it works OK.
