Posted (edited)
在创建新的GDTF文件后,组件模型是自定义的(由我自己创建并上传)。任何控制台中都没有组件模型。解压GDTF文件后,文件夹中没有组件模型(由我自己创建)。默认模型是(例如立方体和圆柱体)。
SAN@FG-780@QWRV1.2.gdtf
Edited by MA3 YIN
Hello, i looked at the file and the 3D files have incorrect file name, someone/something added "3ds" to the name. The name should only contain the name of the file, not the name of the folder. Once the filename is correct, the builder shows the file correctly. See attached. If you modify the files by hand (i presume that this was the reason), you need to be careful.
