MA3 YIN Posted June 27, 2025 Posted June 27, 2025 Hello, group leader. I downloaded the GDTF file and tested it. There is a model in it and it can be used. I modified the model path in the information table of the original file and recompressed it into ZIP format. I changed the suffix to GDTF and it cannot be used. Is there a problem with this method? Where is the bitmap? Group leader, how did you modify the path? SAN@FG-78000@9999).GDTF
Petr Vanek - Robe Posted July 9, 2025 Posted July 9, 2025 Hello @MA3 YIN, the issue you have is that you created an extra folder called "SAN@FG-78000@9999 - 副本" in the GDTF file. This folder "SAN@FG-78000@9999 - 副本" must not be there: It has to have this structure: Hope this helps
