ArekGolab Posted December 9, 2025 Posted December 9, 2025 Hi all! I'm working on my first fixture in GDTF. It's for a chinese LED Bar with Tilt, and zoom options that were bought in venue I work in. Already made first mode - and it seems to work good both in visualizer and with the real fixture. Now what I wanted to do is second mode, which have same first 26 channels, and then added 12 dimmers for the main pixels - and here I can't really make any progres. I was looking into some other fixtures, but it seems to me it's done same way - but I must miss on something here. Can someone look into it, and maybe help with what I'm doing wrong? Best regards, Arek ETS@Super_DOT_LINE_4012@WIP_1.gdtf
Petr Vanek - Robe Posted December 11, 2025 Posted December 11, 2025 Hello, please look at this video You can also look at the Robe CycBar 15X, or the Tetra2. Hope this helps, Petr 1 1
ArekGolab Posted December 11, 2025 Author Posted December 11, 2025 Thank You Petr! This was very helpful and my problem was solved in minutes. For anyone interested - I was trying to make virtual channels for the pixels, when what I should have done was create normal dim channels, but connected to the main pixel/beam geometry, and then just put proper adress offsets to my pix references. 1
