Neil Roehrborn Posted February 1 Posted February 1 I am having some trouble with this GDTF file for the Chauvet Storm 3 Beamwash-2. I would like to use the Standard 35 Channel mode. When I pull the GDTF File into Vectorworks/Vision I have control over it but the color is always wrong. The Mix colors do not work and the color is always the 2700K orange from the Color wheel. If I use the Color Macro channel on my console the visualizer color will change with the Macro Color channel but it always over-rides the RGB channels. I have also tried this with the Basic 3 38 Channel mode and get the same result. For testing I used the Vectorworks fixture mode and then created the same light with the GDTF file from here. I double patched them in the console to rule out any weird profile issues in the console. The Vectorworks fixture mode works fine, and the GDTF profile is still orange. I am pretty confident there is an issue with the color macro on this profile. I edited the file and changed the color of the first slot on the color wheel from orange to blue, and now it renders blue all the time in vision unless I change the color macro channel. In theory a DMX value of 0 should cause the color wheel to have no effect and allow RGB mix to happen. How do can this be corrected on this file? Thanks for any help offered! Neil Chauvet_Professional@Maverick_Storm_3_Beamwash-2@Rev_1.1.0.gdtf
Petr Vanek - Robe Posted February 2 Posted February 2 Hello, make sure that at DMX 0 you select a slot without a color - it will have just the default white. see it for example here: https://gdtf-share.com/help/en/help/gdtf_how_to/key_handle_wheels.html Cheers Petr
