Hi,
is there a reason why the basement renders in the wrong orientation? (Found this with a LEDBeam 350 and T1)
When placing a hanging fixture In VW, if you want the cables US and tilt the fixture "up" towards the audience, you need to rotate the fixture 180° around the Z-axis. The pigtail shows US. – In MA3, the same fixture shows the pigtail on the DS side?
13 hours ago, mdaszenies said:
Hi,
Hello,
the fixture is created correctly as the real world device, you can see this in the GDTF Builder and in gMA3. Make sure you have updated your VW, also check in VW forum or with your VW support for the required VW settings. Kind regards Petr
