How to implement  rgb led ring on front of a beam fixture? I cannot get this to work. If I have the beam working then the ring doesn't work and I have the ring working the beam isn't working. In geomtries I have Beam and ring under each orther. Beam is set to geometric type beam when I set ring also to geometric type beam the ring is working but the beam not anymore. If I set the ring to colorfilter the beam is working but the ring not. Which geometric type the ring needs to be? The ring geometrie is behind the Beam geometrie. Ring geometrie is 20mm wider than the beam geometrie so a ring should be visible. Do i need to override something under DMX with "add relation"? Tried erverything but can't get it to work in GMA3.
Anybody know any working example fixtures?
