Hello to everyone.
I am trying to create a GDTF file for the beam moving light fixture. The file is attached below.
Everything seems functional at first glance, but there are several nuances that prevent me from considering the file fully operational. Perhaps someone would advise on where I might be going wrong and how to fix it?
My first question concerns the geometry. I started with a Moving Head template in the Builder, replacing the existing Base, Yoke, and Head models with my own mesh files and adding an LED ring. The 3D models were created in Vectorworks (Generic solids, textured by Default Instrument Black), converted to FBX format, imported into Blender for minor modifications (to reduce the vertex count), and finally exported as GLB files.
I initially tried converting from Vectorworks to 3DS, but that resulted in a much higher vertex count with all other aspects were the same.
The issue with the geometry is that when the GDTF file is used in Vectorworks with the "Use GDTF Geometry" option enabled, the appearance of the fixture becomes distorted.
 The same happens in the grandMA 3D Viewer: while the Pan/Tilt functions itself does not works, but Pan/Tilt rotation functionalities behaves as expected.
In the Vision, things look mostly fine and Pan/Tilt functions behave correctly; however, the Pan/Tilt rotation is not continuous—it behaves like indexation, the yoke or head only turns for about 3½ turns.
Non-working continues rotation in the Vision is not as important as how the fixture looks in the MA 3D Viewer.
Does anyone have any ideas about this?
Perhaps someone could suggest how to fix it?
Lunax@StiX_BEAM_M1@1_5_6.gdtf
Hello @Andriy K, when you do your work in Blender, before you do the export to glb, press Ctrl-A (Apply) and select "All Transforms", to bake the rotations and all other modifications to the file:
That will fix it:
I only checked pan/tilt/pan rotation/tilt rotation and that worked.
