synapse_gh Posted January 9, 2020 Share Posted January 9, 2020 Hi all, I've read through the documentation and may have missed this - does the GDTF standard specify how a given attribute should be laid out within a channel? For example, on Shutter: 0-10 Shutter closed 11-20 Shutter open 21-60 Strobe synced, slow --> fast 61-100 Strobe random, slow --> fast 101-120 Pulse open, slow --> fast 121-140 Pulse closed, slow --> fast 141-235 Manufacturer's choice It's something I've been hoping for for quite a while, would be great if GDTF solves it! Link to comment Share on other sites More sharing options...
mgeasey@clearallvisualsllc.com Posted January 9, 2020 Share Posted January 9, 2020 Hey Synapse, Welcome to the forum! To acheive this the main channel function should be shutter and then under that you can add the appropriate channel functions to this channel. See here: Hope this helps! Cheers! MattG 1 Link to comment Share on other sites More sharing options...
synapse_gh Posted January 10, 2020 Author Share Posted January 10, 2020 Hi Matt, This looks like a great mechanism is provided to build out each channel, but I can't quite make out the image. Is there any sort of standard for how functions are to be laid out within the channel? For example, on shutter, currently each manufacturer puts the "strobe random" function in a different part of the 0-255 range, which means those of us hopping from house rig to festival rig to tour rig are constantly updating palettes just to accomplish the same one thing. If it's possible to get every GDTF fixture profile to put "strobe random" in the same part of the range, that would be amazing - or am I describing a feature that already exists? Link to comment Share on other sites More sharing options...
mgeasey@clearallvisualsllc.com Posted January 10, 2020 Share Posted January 10, 2020 Hey Synapse, What your describing/hoping for is a function of the control platform i.e. MA3/MA2, Hog, Chamsys, etc etc to match the Channel functions for each fixture. GDTF is helping create a common naming scheme for all fixture types to handle this transaction easier so that when the operator needs to "clone" or get info from one fixture type to another it has a common name to look for. Asking anything to "re-map" DMX is not really a thing, at least from the GDTF side of things. I hope this helps! Cheers! MattG Link to comment Share on other sites More sharing options...
Petr Vanek - Robe Posted January 21, 2020 Share Posted January 21, 2020 Hi all, best way to understand this is not to think about how you control it, but how will a visualizer know what to do. So you have Shutter open/closed, Strobe, Strobe Pulsing opening/closing etc. As each of these require different way to visualize, each requires a new Channel Function with it's attribute. cheers Petr Link to comment Share on other sites More sharing options...
