GDTF discussion on LD at Large Podcast
Petr Vanek - Robe
Thanks @mgeasey@clearallvisualsllc.comand others for the GDTF conversation on LD at Large Podcast. Good conversation, questions and answers. Here is the episode:
https://plsn.com/podcasts/gdtf-or-gtfo-podcast/
Below are some of my notes and comments, mostly from the Robe side, feel free to ask for more clarification.
- Matt kicks the discussion off by explaining that GDTF is not only a DMX profile but a container with data which a console, planning tool or a visualizer can use for their internal use cases.
- Discussions about Media Servers, "standard vs custom" mapping/profile, the bottom line is: besides "standard profiles", Media Server can generate GDTF on the fly, even for a "non standard mapping", the GDTF advantage is that now it can be implemented by the software only once in a open, standard format → GDTF, rather then having to implement each manufacturer's library type/style. Plus, there are media server specific features in GDTF 1.1.
- Discussions about attributes and naming:
    - will attributes grow out of proportion while still allowing custom ones? The development group tries to be flexible and at the same time good gatekeepers of attributes. For a simple explanation, Attributes, for the most time, describe real-world behavior, which is then implemented by visualizers. This can help a lot when choosing/searching for a correct attribute.
    - can channels be named by the user? Yes, GDTF provides possibility of naming channels/channel functions via the Pretty (this is used in a global context on MA3). The first ChannelFunction of a channel would also be considered when looking for a channel name, so it's Name and OriginalAttribute values should be used, by convention.
    - where do we request new attributes? Requests for attributes can be submitted via forum.
    - where do we request new attributes/features? Either via forum or developers can join our technical meeting. People do actually join, on occasions or regularly. We do see representatives of ETC, Chamsys and others in the bi-weekly Zoom call.
- Is detail about shortcut of movement of an element defined - Yes, this is supported via dedicated attributes.
- Can random strobe be 100% emulated? At this point not to the extend to 100% replicate exact behavior (algorithm) which often is not available, but randomness is supported.
- Are weight, power draw of a device supported by GDTF? Yes, these parameters are part of the soon to be published 1.1 version.
- What about clamps weight? Clamp/adapter/accessories can be an extra GDTF file. Also, GDTFs could be linked to each other. The planning software then can use there values to calculate total weight.
- Is iris open/close at 0/1 or 1/0? We define the real world behavior in GDTF. User then can modify the behavior of the console in the console.
- Who "signs off" a GDTF file? Ideally, a fixture manufacturer is the one who makes the file. Having responsibility for one file (GDTF) is, while still quite complex, possible.
Cheers
Petr
