How it should work Effect(n)Adjust(m) ?
Paolo.Prolights
Hi there,
Has anyone used the Effects(n)Adjust(m) attribute successfully?
After 2 hours of writing dozens of channel sets in dozens of logical channels divided into master containers under this attribute, I uploaded the file to the share.
Today I reopened the file in the builder and found an unpleasant surprise; the Effects(1)Adjust(1) attribute and the Effects(1)Adjust(2) attribute have disappeared with all their contents!
In practice, I find the dmx channel with only the associated geometry.
By uploading the file to the share, all the content of these channels has been deleted!
I tried to do it from scratch with only one logical channel, without master container and only one channel sets but I get the same result, it seems that this attribute is simply not recognized, in fact it is not even present in the Summary tab under the Attributes item.
Is not even present in the Summary tab under feature groups beam.beam as I expect it should be as per spec:
<Attribute Name = "Effects (n) Adjust (m)" Pretty = "FX (n) Adjust (m)" Feature = "Beam. Beam "/>
Thanks for your attention.
Best regards.
Paolo.
  • 3 months later...
Hi there,
these attributes still not working so build complex fixtures with parameters linked to effects is not possible.
How do you suggest to workaroud to build something like the following?
ch_1 "Mode Selector":
FX: 000-012
Source Emulation : 013-024
CCT: ...
HSI: ...
ch_2 "FX selector":
NoFunction: 000-001 (MMC ch_1 - dmx 013-255)
FX_1: 002-003 (MMC ch_1 - dmx 000-012)
FX_2: 004-005 (MMC ch_1 - dmx 000-012)
FX_3: ...... (MMC ch_1 - dmx 000-012)
ch_3 "Parameter 1":
Saturation: 000-255 (MMC ch_2 - dmx 002 - 003)
CCT Range: 000-255 (MMC ch_2 - dmx 004-005)
ch_4 "Parameter 2":
Speed: 000-255 (MMC ch_2 - dmx 002-003)
And like this for 7 parameters.
Best regards.
Paolo.
  • 2 weeks later...
  • 1 month later...
