Sumolight Posted October 25, 2022 Share Posted October 25, 2022 Hi people, I'm stuck in the very beginning: I uploaded a mesh using a .3ds-file and in the same session it all seems to be fine and visible. But when I re-open or load that configuration I'm not able to see the 3D-model anymore but all other data is still there. What am I doing wrong? Thank you very much in advance .3ds-file is attached SM_9443_SUMOMAX_for_GDTF_03_Mesh_export.3DS Link to comment Share on other sites More sharing options...
Petr Vanek - Robe Posted October 26, 2022 Share Posted October 26, 2022 Hello. I think the issue is in the extension. If you rename it to *.3ds , then it works. Maybe you cannot even see this on the operating system of your choice... not sure. I will report this. Kind regards P. 1 Link to comment Share on other sites More sharing options...
Sumolight Posted October 31, 2022 Author Share Posted October 31, 2022 On 10/26/2022 at 5:56 PM, Petr Vanek said: I think the issue is in the extension. If you rename it to *.3ds , then it works. Hi Petr, renaming *.3DS to *.3ds seems to work. Thank you! 1 Link to comment Share on other sites More sharing options...
