Add Channel Functions
Channel functions are used for bundling specific channel values, for example a strobe function of a shutter channel.
Important
The value range of a DMX channel must completely be filled with channel functions. There must be no gaps and there must be no overlapping values.
Refer to the fixture’s DMX table and identify the available channel functions.
Important
Every DMX channel must at least have one channel function and may have channel sets.
  • By default one channel function is created for every DMX channel.
Edit Channel Function window Edit Channel Function window
  • A channel function gets a name by default. This name can be changed.
Important
The names of all channel functions of a DMX channel must be unique.
  • To open the Select Attribute window, click into the attribute input field. The Select Attribute window opens. Select the Attribute from the dropdown menu or search for it in the search field.
Select attribute window Select attribute window
  • Select the matching attribute from the attribute list.
For faster search through the attributes, use the selection box Feature Group as a filter, for example Position.
Selection box Feature Group window Selection box Feature Group window
  • To define the lowest DMX value of this channel function, fill DMX From.
  • To switch the readout from 8bit, 16 bit, 32bit, 64bit to %, click the arrow right button.
Changing the readout does not change the resolution of the property but allows to enter the values in a different resolution or as percentage.
  • To define the highest DMX value of this channel function, fill DMX To.
  • To enter the physical value related to the lowest DMX value, fill Physical From.
  • To enter the physical value related to the highest DMX value, fill Physical To.
Example:
The DMX channel shutter of Robe’s Megapointe has several different channel functions:
Shutter open
Shutter closed
Shutter strobe
Shutter strobe pulse open
Shutter strobe pulse close
Shutter strobe random
Every channel function must be added individually.
The unit of the channel function is automatically defined when selecting the matching attribute!
Channel functions shutter Channel functions shutter
