sbolman Posted October 16, 2020 Share Posted October 16, 2020 Hi all, I'm building a GDTF fixture for the first time. I'm trying to create a Wybron Nexera, which has an incandescent dimmer and CMY color mixing. I built the fixture in GDTF maker and then added a break for the dimmer by editing the .xml file. When I merge the fixture into Vision, it shows up as only having one channel and for some reason having multiple Color Temperature and Candela values, even though they are only listed once in the .xml file. When I select the fixture it turns on but I am unable to control it in any way from the console. I would love some advice about how I might be able to fix this! Thanks, Scott Wybron@Nexera@test.gdtf Link to comment Share on other sites More sharing options...
moritzs Posted November 3, 2020 Share Posted November 3, 2020 Can you attach the MVR that you are using to merge this into vision? Link to comment Share on other sites More sharing options...
