NRG Sille Posted June 15, 2022 Posted June 15, 2022 (edited) I am still missing attributes for effect engines of most fixtures, there are already attributes for Effects(n) and ColorEffects(n) and there are attributes for Effects(n)Rate, Effects(n)Fade, EffectsSync, Effects(n)Pos and Effects(n)PosRotate. What I am missing is Effects(n)Size, Effects(n)Level and Effects(n)Position. And the same attributes should exist for ColorEffects(n), this would make it possible to create a lot more fixtures, wich I am not able to create at the moment 😉 Edited June 15, 2022 by NRG Sille
NRG Sille Posted June 15, 2022 Author Posted June 15, 2022 And there is a wildcard missing, It should say Effects(n)Sync, not only EffectsSync
Petr Vanek - Robe Posted June 17, 2022 Posted June 17, 2022 Thank you! Submitted as https://github.com/mvrdevelopment/spec/issues/128 1
