Petr Vanek - Robe Posted July 10, 2023 Share Posted July 10, 2023 Hello all, we have released another big update to the GDTF Builder. Besides adding new functionality, improvements and bug fixes, we have optimized parts of the builder, making for example Geometry loading orders of magnitude faster. We have also added new wizards: one for adding and placement of several Geometries, another to make a bulk insertion of Wiring Objects with predefined connectors like XLR5, True1 and so on. Let us know if you find any issues and enjoy this new update! New Features Copy / Paste Wheels between different fixtures Display user name in the title bar Start using ModifiedBy in revisions to be able to see where an issue possibly comes from Show Channel Highlight and Default values in DMX Mode overview Geometry tree operations are now much faster Add predefined Wiring Object types Arrangement Wizard for Geometries Here is a list of reported issues and requests, which is now resolved 🙂 Improvements Upload of large meshes does not give the user any feedback The duplicate UUIDs error should give the user more guidance on how to resolve it Add option to allow DMX count to continue from previous DMX Break range in the DMX Mode overview screen Display RDM/SW in decimal DMX Table in DMX Mode Overview should be multi line instead of heaving a scroll bar Give more detailed information about the csv for spectral data When starting "a new" device file from an "old" one, indicated this in revision history Visually separate DMX modes, for example do a zebra table of DMX modes Visually mark attributes without Pretty name Duplicating DMX mode will paste channels with Initial channel function reset to first channel function DMX Logical Channels can collapse Add more detailed information to the edit prism facet dialog The duplicate UUIDs error should give the user more guidance on how to resolve it Display RDM/SW in decimal Sorting dmx channels by coarse when channels have the same break Bugfixes Model: can not remove Low/High model glb and 3ds and svg top / front / side Sort channels should consider break, rather then sorting 1 1 2 2 each after the other If DMX Mode is missing link to a Geometry, Builder shows an error which cannot be found No error is displayed if a gdtf is imported, that has two geometries with the same name With multiple geometry trees, the builder doesn't highlight beam geometries of the second three Geometry size is affecting model size Tool tip of glb meshes says 3ds instead of glb SVG offset lost upon viewing Instant crash if i clear value of a geometry rotation's axis and switch to another axis New Geometry in Paste Mode is missing scrollbar Additional measurements of a emitter are exported with physical = 0 Message is displayed that a top level geometry is not referenced even if it is referenced to by a geometry reference. Fix crash on summary click after duplicating DMX Mode with virtual dimmer with attribute relations After creating a Duplicated DMX Mode with virtual dimmer, you cannot delete attribute relations in the duplicated mode Revision time is one hour back when saving GDTF History of revisions is lost if I consecutively work on the same file Builder freezing with specific file The builder should respect the timeout of the cookies and prompt the user a login popup once the cookie expired Fixing re login error Adding seed verifying request for relogin modal Missing attribute while copy/paste DMX channel in dev. version Fixing do not upload to the Share checkbox lost Fix crash copy, paste dmx channel, then delete previous channel and go to summary The GDTF Share button in the builder editing always points to the live share Templates miss icon after cookie expires When i open a file which has white emitter linked to a beam geometry, the builder doesn't show it If DMX Mode is missing link to a Geometry, Builder shows an error which cannot be found Add option to allow DMX count to continue from previous DMX Break range in the DMX Mode overview screen Fix can not copy and paste wheelslot with no filter Copy/paste mode lost attribute issue. Attributes that did not exist in the fixture before pasting are lost during saving. Use Parent Physical Warning shows even in legitimate usage cases Link to comment Share on other sites More sharing options...
