joselhsa Posted July 13, 2023 Posted July 13, 2023 Hi, due to my limited knowledge i am making my fixture file from existing movinglight and editing them, everything seems fine but i have a problem with panning. The panning is going in the opposite direction( when the 3d goes right the physical fixture goes left). Also, how do i set the starting position, because when my physical fixture is facing right, the 3d is facing front
Petr Vanek - Robe Posted July 13, 2023 Posted July 13, 2023 8 hours ago, joselhsa said: Hi, due to my limited knowledge i am making my fixture file from existing movinglight and editing them, everything seems fine but i have a problem with panning. The panning is going in the opposite direction( when the 3d goes right the physical fixture goes left). Also, how do i set the starting position, because when my physical fixture is facing right, the 3d is facing front Hello, this is done by adjusting Physical From/To properties. Here is how the DMX maps to physical: Here is another example for channel sets: So to make it simple: you need to invert the range (positive/negative values) of the Physical From and Physical To. You could also go through the more comprehensive explanation here: cheers Petr
joselhsa Posted July 14, 2023 Author Posted July 14, 2023 thank you for your help i can now sucessfully patch my fixtures and they are also working in visualizer 1
