Thibault Godmé Posted May 25, 2024 Posted May 25, 2024 Hello everyone. First, i hope i'm in the right place to ask question... If not, please tell me... I'd like to create a fixture made of RGB and White Led Stripes. I added meshes from SketchupPro (3ds format), and i would like to make them "Glow" in the ma3 visualiser. I don't want to see the beam, but only the sources, even in a very simple way... I don't need to see all the idividual Leds. Does anyone know how am i suposed to do that ? My fixture is composed of 4 separated led stripes ( 1rgb+3white). I made a "main" geometry with my custom mesh, and 4 sub empty geometry, 1 for each stripes. Added all my Chanels in the GDTF builder, and added virtual dimmers directly in the ma3 fixture builder (v2.0.0.4). I precise that my fixtures works well in the ma3 fixture sheet. Thank's for your answers 😉
Petr Vanek - Robe Posted May 27, 2024 Posted May 27, 2024 Hello, you can make the beam large (like a tube) and set the Beam geometry's Beam Type to None or to Glow: See here: https://gdtf-share.com/share.php?page=home&manu=User+Test&fix=RGB+Tube I didn't test in gMA3 but i presume that it would work, Hope this helps, cheers Petr
Thibault Godmé Posted May 27, 2024 Author Posted May 27, 2024 Works pretty well ! Thanks a lot. Just have to add many many beams for each sides of my structure. Just a little problem in ma3 visualizer. All the beams are randomly placed when i patched my fixture. Problem solved by deleting the main geometry's model, but it's ok cause we can see the beam's models when they're off. Thanks a lot for your help Petr. 1
