Lennarthd1 Posted December 11, 2024 Posted December 11, 2024 Hello Guys Today I built a fixture file for a new moving head prototype. The file also works perfectly with all functions. But in Grandma3 3D the moving head does not light up but in real life it does. I Cant solve this problem i tried evrything. Padura@Seth_650@3D_Test (18).gdtf
Petr Vanek - Robe Posted December 14, 2024 Posted December 14, 2024 Hello @Lennarthd1, you have done mostly good job on the profile. The issue is in colors (RGB) being set as default at 0, so make sure to bring colors to full, as @full will not do so. The next issue is in the Iris channel, the Physical From, To must be 0 to 1. There are other small things, but mainly that your 3D models are too detailed, perform some decimation on them, to be under the 1200vertices in total.
