ssm2017 Posted September 28, 2023 Share Posted September 28, 2023 (edited) Hello, i have not found a mvr forum so i am asking here. I do not have any software to build mvr file except ma3 so i am wondering if i am following the good process. I would like to build a mvr file for a theatre. I have built a gdtf fixture without dmx channel (one mode is mandatory) and this fixture is containing a geometry with several subgeometries (geometries are linked to models built with blender and exported to glb files). The main geometry is the stage floor. The sub geometries are walls, pipes, seats, curtains, roofs, catwalks, etc... And then i have imported this gdtf inside ma3 and exported to mvr to be able to share it away. It is working but is it the good process to build a mvr file containing architecture items or is there a better way ? Edited September 28, 2023 by ssm2017 Link to comment Share on other sites More sharing options...
Petr Vanek - Robe Posted September 29, 2023 Share Posted September 29, 2023 Hello, Yes, that's not a bad way, certainly working and for free. Another ways would be for example: - load the 3d models into gMA3 as 3D symbols, or - use Production Assistant, also for free, to do this in a bit more "mouse/keyboard" friendly way, Then export as MVR. As for your MVR file, would it be possible for you to share it here? Cheers Petr Link to comment Share on other sites More sharing options...
