vixzy Posted January 16, 2024 Share Posted January 16, 2024 Hi! The company i work for has just bought a LED bar with 20 pixels RGBW. One of the modes on the bar is 80 channels, wich is 4 channels rgbw for each pixels. Instead of just having just RGBW controll it would be nice to have a virtual dimmer to controll them. Either for the entire fixture or for each pixel. I have tried to add a virtual dimmer to the main fixture and also per pixel but I can't get it to work. What would be the correct way to add a virtual dimmer to controll the pixels? Link to comment Share on other sites More sharing options...
Petr Vanek - Robe Posted January 16, 2024 Share Posted January 16, 2024 16 hours ago, vixzy said: Hi! The company i work for has just bought a LED bar with 20 pixels RGBW. One of the modes on the bar is 80 channels, wich is 4 channels rgbw for each pixels. Instead of just having just RGBW controll it would be nice to have a virtual dimmer to controll them. Either for the entire fixture or for each pixel. I have tried to add a virtual dimmer to the main fixture and also per pixel but I can't get it to work. What would be the correct way to add a virtual dimmer to controll the pixels? Hello. For Virtual dimmers, see the Help page here: https://gdtf-share.com/help/en/help/gdtf_how_to/key_create_virtual_channels.html and also see the short message here: Hope this helps, Petr Link to comment Share on other sites More sharing options...
vixzy Posted January 23, 2024 Author Share Posted January 23, 2024 On 1/16/2024 at 7:45 PM, Petr Vanek - Robe said: Hello. For Virtual dimmers, see the Help page here: https://gdtf-share.com/help/en/help/gdtf_how_to/key_create_virtual_channels.html and also see the short message here: Hope this helps, Petr Thanks! This was the part I had missed! Was no fun to add it to a 80ch rgbw profile tho! Link to comment Share on other sites More sharing options...
Petr Vanek - Robe Posted January 24, 2024 Share Posted January 24, 2024 21 hours ago, vixzy said: Thanks! This was the part I had missed! Was no fun to add it to a 80ch rgbw profile tho! Great! If it was too much work, Geometry References might have been used, to define the section (geometry and it's properties) only once and then re-use it as many times as needed: Or you can also use the Geometry Arrange/Multiply tool. It can multiply regular geometries and also geometry references... Link to comment Share on other sites More sharing options...
