Prolights Posted February 14, 2025 Posted February 14, 2025 Hi everyone, I found a bug in the builder. Channel set physical values are reset to 0-1 when the channel function comes from another channel using copy and paste of the channel function. Could you please submit this to the developers? Thank you. Best regards. 1
Petr Vanek - Robe Posted February 19, 2025 Posted February 19, 2025 @Paolo.Prolights can you still replicate the issue? I cannot, but perhaps there is something i am missing? We did release a new builder on Monday... but i don't think we were intentionally fixing this bug. Thank you for letting me know.
Prolights Posted February 21, 2025 Author Posted February 21, 2025 Hi Petr, I think I understand why you can't replicate the problem, which is still present today. If you copy a channel function from one channel and paste it into another channel this problem does not arise. Occurs only if the copied channel function comes from a mode master container. It happens both if you paste it into a channel without master mode but also if you paste it into a channel with master mode, so I think the problem is related to the copy of the source channel function and not to the destination channel. Thanks. Best Regards. 1
Petr Vanek - Robe Posted February 28, 2025 Posted February 28, 2025 Thank you. I will try to replicate and will report to the developer team.
