Ringen Posted February 23, 2021 Share Posted February 23, 2021 I just noticed that importing a GDTF file into MA3 v1.4.X will strip away my Channel Function Names. MA3 will generate some useless ones instead. E.g. I had 3 channel Functions: No Key / LumeKey / Chroma Key and MA3 change that to: Key 1 / Key 2 / Key 3 (Based on Attribute = "Key") If I change the names in MA3 and export back to Builder those names will appear. Only to disappear again if take it back to MA3. I assume this is a bug in MA3? While on the subject, can anyone explain why MA3 uses Attribute to indicate Channel Function on the Encoder bar? As there is a fair chance the same attribute is in all Channel Functions you often get a list like: G1 G1 G1 G1..... Link to comment Share on other sites More sharing options...
