Hi, when I import any GDTF file from Robe Lighting into Unreal Engine (4 or 5), there are no data visible. For example Clay Paky files work normal. Any help with this issue please?
  • 2 weeks later...
  • 6 months later...
It seems that Robe ones do not import because the GDTF includes an SVG which Unreal reads as XML and trys to interpret as the definition file. You can open the GDTF file as a archive using something like 7Zip, delete the svg and then import the GDTF file and it will work fine. I've reported this to Unreal, hope for a fix soon?
  • Thanks 1
