Snabbelicious 0 Posted January 13 Share Posted January 13 I am trying to create a gdtf file for the JB Lighting P12 Spot (because for some reason the MA3 does not load the MA2 library). Yesterday I tried the first time, it took 2 hours and at the end it wouldn't upload. When I reloaded the page all my work was gone...The second time I started again from scratch, and halfway through I reloaded the page just to check the session was saving and everything was gone again. Today I was trying for the third time, and for some reason after 10 minutes or so my session does not sync anymore and any work I do after that is lost! I'm slowly adding information, but I have to reload the page very often just to check the information is saving, this is not inteded behavior right? Am I doing something wrong or is the builder just buggy? Quote Link to post Share on other sites
Petr Vanek 18 Posted January 14 Share Posted January 14 Hello @Snabbelicious, do you use any adblocking software? Or have many tabs open? The builder keeps data stored locally in your browser session. If you "just reload" the page, normally the last fixture is stored under the "Restore last session" icon. Or is there a particular sequence that you know would trigger this? Thank you Petr Quote Link to post Share on other sites
Snabbelicious 0 Posted January 15 Author Share Posted January 15 On 1/14/2021 at 7:37 AM, Petr Vanek said: Hello @Snabbelicious, do you use any adblocking software? Or have many tabs open? The builder keeps data stored locally in your browser session. If you "just reload" the page, normally the last fixture is stored under the "Restore last session" icon. Or is there a particular sequence that you know would trigger this? Thank you Petr Sorry for the late reply. I do use adblocking software, and turned it off without much result. I also tried this process on another computer with the same experience. I tried to narrow down the problem by changing only a few little things at a time and then refreshing the page and see if the changes saved. It is a bit fickle, but it looks like I have the most problems when I try to edit the channel sets of the first gobo wheel. I can add the empty sets, but as soon as I try to set the wheel slot, or change the dmx information it won't save that and anything I do afterwards. I did manage to create a "working" gdtf file by only filling in the dmx channels and not creating any channel sets, but would still like to finish the file properly. Quote Link to post Share on other sites
Snabbelicious 0 Posted January 15 Author Share Posted January 15 Tried another browser (original was Chrome, new was Edge), didn't make much of a difference either. I did find out however that if I just press the upload button directly, instad of going through the tabs that it will upload the file including the changes. However when I refresh the page all new info is still gone, and I have to upload the new gdtf file to continue. Quote Link to post Share on other sites
NRG Sille 1 Posted January 16 Share Posted January 16 I got the same problem, yesterday I created a file and uploaded it to gdtf share but after upload the file got messed up so I wanted to edit the file again to fix it, but when I press "Upload" the file in gdtf share does not get replaced and I can not download the fixed filee from the builder. Another question: There is a new option for default DMX in every container, but in case of multiple features in one channel there are now multiple defaults. Whats the sense of this? I attached a screenshot Quote Link to post Share on other sites
NRG Sille 1 Posted January 16 Share Posted January 16 PS - it is also not possible anymore for me to delete the faulty gdtf in gdtf share. The progress window lasts forever Quote Link to post Share on other sites
Petr Vanek 18 Posted Sunday at 02:09 PM Share Posted Sunday at 02:09 PM 17 hours ago, NRG Sille said: I got the same problem, yesterday I created a file and uploaded it to gdtf share but after upload the file got messed up so I wanted to edit the file again to fix it, but when I press "Upload" the file in gdtf share does not get replaced and I can not download the fixed filee from the builder. Another question: There is a new option for default DMX in every container, but in case of multiple features in one channel there are now multiple defaults. Whats the sense of this? I attached a screenshot GDTF 1.1 specifies default values for each ChannelFunction, because ChannelFunction could have a value range, which is outside of a default value defined on a Channel. The Channel also has a "default channel function" which is giving default channel behavior. Quote Link to post Share on other sites
Petr Vanek 18 Posted Sunday at 02:13 PM Share Posted Sunday at 02:13 PM On 1/15/2021 at 8:58 PM, Snabbelicious said: Tried another browser (original was Chrome, new was Edge), didn't make much of a difference either. I did find out however that if I just press the upload button directly, instad of going through the tabs that it will upload the file including the changes. However when I refresh the page all new info is still gone, and I have to upload the new gdtf file to continue. We will be pushing some improvements out soon. This is partially related to the recent transition to GDTF 1.1 in the builder (Builder v1.4) and to the move to VPLT as a third party independent entity providing oversight over the hosting, in order to maintain an independence from the founding members. We use the builder every day and while we have seen some issues (and we keep reporting them), we were able to maintain our work normally. Quote Link to post Share on other sites
Petr Vanek 18 Posted Sunday at 02:14 PM Share Posted Sunday at 02:14 PM 17 hours ago, NRG Sille said: PS - it is also not possible anymore for me to delete the faulty gdtf in gdtf share. The progress window lasts forever This is new issue, we have seen this on Friday afternoon. Mark the file WIP @NRG Sille please, before this issue is ironed out. Cheers Petr Quote Link to post Share on other sites
Snabbelicious 0 Posted Sunday at 09:04 PM Author Share Posted Sunday at 09:04 PM 6 hours ago, Petr Vanek said: We will be pushing some improvements out soon. This is partially related to the recent transition to GDTF 1.1 in the builder (Builder v1.4) and to the move to VPLT as a third party independent entity providing oversight over the hosting, in order to maintain an independence from the founding members. We use the builder every day and while we have seen some issues (and we keep reporting them), we were able to maintain our work normally. Thanks for the information. It's strange that it is working normally for some people, but for me almost unusable. If I can be of any assistance I'll be glad to provide any help I can give (testing, more information, etc). For know I'll just use the incomplete gdtf library I managed to create, but leave it on WIP. At least I can control the fixture. Once the issues are sorted out I'll update it with the rest of the information. Quote Link to post Share on other sites
