  • Who's Online   0 Members, 0 Anonymous, 1 Guest (See full list)
    • There are no registered users currently online
This stream auto-updates
  1. Last week
  2. Earlier
  3. If the effect uses 2 channels (16bit) and you want to enter the data in 8bit fashion (0-255 values), you somehow have to define the value for the second channel. In the input field, the first value (from the left) is what you most likely have in your DMX table, the second value (after the slash "/"), is most typically will be 0 for you, except for 255, which will be 255/255 (to have full maximum value). Hope this helps. Maybe discuss this with your R&D people, to have more clarity if needed... they will be able to help you too. cheers Petr
  4. @Petr Vanek - Robe Could you please expand a bit on the DMX values in 8bit mode and how its 2 numbers separated by a "/" (0/0, 128/0, 255/255)?
  5. Hello @CarlosDVS, switching the input field between 8/16/24/32/% is just a view on how you enter the data. So by switching it to 8, you can enter your data in the 8bit, as per your DMX table... see for example here: When switching between these values, you can see what you values look like in different resolutions or a percentage:
  6. Hey Everyone I'm looking for a little clarity on how to program 16bit channels. I'm writing a profile with a 16bit channel(s) that control focus distance. I know how to set the resolution and designate coarse and fine channel numbers, but I need to add additional attributes for pre-defined focus distances. My DMX table gives me values from 0-512, but when I change the channel attribute from 8 to 16bit I'm prompted to enter values between 0-65535 and I'm just not super sure where to go from here. is there any documentation/video resources someone can point me to on the topic? Thanks in advance!
  7. Here is a list of frequent errors we can see some new GDTF authors are making, together with description on how to eliminate these issues. By following this advice you will be creating GDTF files of much better quality. Custom GDTF Attributes Do not define custom attributes. If you think that the attribute you are needing is not in the GDTF Builder, look more closely. In 99%, the needed attribute is already defined in GDTF and thus it allows all software utilizing GDTF to know which real world behavior is described by that GDTF attribute. If unsure about creating a new attribute, ask in the forum, especially if you want to be sure that your GDTF file is correct. Here are some commonly missed GDTF attributes: Dimmer, which is controlling intensity of the device. Do not create an attribute "Intensity". Colors. Do not create "Red" of "Green". These already exist as for example ColorAdd_R, ColorAdd_G, ColorAdd_B for direct color mixing, ColorRGB_Red, ColorRGB_Green, ColorRGB_Blue for indirect color mixing, ColorSub_C, ColorSub_M, ColorSub_Y for Cyan, Magenta, Yellow subtractive color mixing. You can view the list of all GDTF attributes with extended description for each item here. Coarse and Fine Channels When defining a DMX Channel, you can choose a Resolution of the channel. This then allows you to assign a DMX offset for Coarse and Fine, as per image below. Do not create channels "Dimmer Fine" or "Red Fine" channels. Emitters/Filters Only define a color Emitter or a Filter if you have measurements of the colors. Do not define Emitters/Filters to just click some random R, G, B values. 3D Models Ideally, use a real 3D model of the device. If you do not have a 3D model of the fixture, you can use the default head, yoke, base models provided by the GDTF Builder, if these default models look like the real device you are describing. If the default head, yoke, base models do not describe your device correctly, it is often better to use the predefined cube or cylinder as a model. Do not use for example the default base instead of a generic cube, it will look very ugly. Beam Geometry For beam geometry, typically use a cylinder with a small height. Do not use randomly some other predefined models like the head or base. Hope this helps. If unsure, just ask here in the forum. Petr
  8. Hi AyrtonTerrier, Thanks for reporting this issue. We can reproduce it and I will create a ticket. Best Regards, Daniel
  9. Hello everyone, I probably found a problem loading the builder when you open the file from the GDTF share, It seems that the builder loads the file only on the fixture sheet. If you select another sheet before the file is completely loaded, it will not completely load the file and an error may appear. I have attached a video showing the problem The file used is the Zonda 9 FX from AYRTON 2024-04-24 09-30-22.mkv
  10. GDTF Builder has been updated with the following changes: Ensure that when saving a GDTF file, the spinning animation is closed down after file upload procedure Improved GDTF Share performance when saving GDTF files Do not mark DMX Breaks with offsets larger then 512 as errors Ensure correct reading/writing of GDTF files after copy/paste of geometry references
  11. Hello @Brothers, we are hoping for a fix for this to be released this week. It is pretty difficult to reproduce so we hope we are eliminating the issue. cheers Petr
  12. Brothers
    Saving errors
  13. dmueller
    GDTF down?
  14. Brothers
    GDTF down?
  15. If you have the opportunity, please visit the GDTF Booth in Hall 12.1 stand B41 at the Prolight + Sound. Open manufacturer meeting is taking place in-person at the GDTF booth, on Wednesday at 4:00pm. Location of the GDTF booth on the PL&S floor plan.
  16. Hello @mgeasey@clearallvisualsllc.com, I don´t really understand what you´re doing to solve this problem. I converted a file for Martin MAC Aura XIP to grandma2 but 3d doesn´t work well (screenshot). Could you explain what you´re exactly adjusting
  17. Hello @vixzy i looked at your file. The important thing to realize is that shutter is a different physical behavior then strobe. Shutter can be open/closed (1/0), while strobe is strobing fast/slow (1/s), so for example 20 for fast, 0.3 for slow. For this, define two channel functions, one for Shutter (Shutter1) one for Strobe (Shutter1Strobe): And then adjust the Channel sets to match the speed of the strobing. See attached file where i split the shutter into two functions. Kind regards Petr Etan@Etan_101@Splitting_Shutter_into_Shutter_and_Strobe.gdtf
  18. Hi! Fooling around a bit with the profile i got it working in MA3 3D by changing the first logical channels "Physical From/To" to 1 in both fields. But is this the right way of building the channel? Etan@Etan_101@Rev_1.6.gdtf
  19. Hello, Presumably you are adding Shutter instead of a Strobe, that's maybe why it's not working. Posting a GDTF file here can increase a chance that someone will look at it and can help you. Cheers P.
  20. Hi! When I add any kind of strobe/shutter function to my channel i get no output in MA3 3D unless i bring the channel up to at least 45%. Judging by the channel list for the fixture i should have output when that channel is at 0 and different strobe modes after that. How should I define the Strobe channel for it to work properly? For the moment I cant get my hands on the fixture to see how it actually acts in real life. Its a led mover that one of our suppliers bought a bunch of a few years ago that we use from time to time All tips are very appreciated. Thanks in advance!
  21. Hello @SergeG, is there a GDTF file you could post here for people to look at? cheers P.
  22. Hello all, we have made a public release of the libMVRgdtf library which makes it much more easy for software authors and companies to be able to implement and utilize GDTF and MVR in their products. We had previously been giving access to the Github libMVRgdtf repo on individual bases, the code has now has been released to the general public. The implementation also included the MVR-xchange communication protocol. The library has been used ever since by the Builder and other software. License allows commercial and closed software usage, but IANAL, so check yourself.
  23. I am trying to modify the latest library of the Chauvet f415 projector since the predefined color wheels do not work in the 3D view of the grandma3. I cannot separate the 2 wheels: I have to open the 2 wheels for the projector to start emitting a color, but the 2 color wheels are independent (a predefined color wheel and a temperature wheel color). How should I make this work?
  24. GDTF Builder has been updated with the following changes: Undo for the Physical Description tab has been implemented. Ensure that CIE Color Space representation remains visible when picking a color Provide the GDTF file for download before uploading it to the GDTF Share Improve DMX tab editing performance
  25. Hi Petr Thank you very much for your fast Reply and Help. Now it works as expected. Greetings Lukas
  26. Hello Giannis, we describe the "quality" or "size" of the 3D asset by using vertex count, this being in the Spec and also in the Builder. It is a value commonly seen in 3D software like Blender. I am not sure what a "polygon" would be meaning here - would that be a triangle? As for the level of detail: One can use the provided GDTF Primitives of base, yoke, head, triangle, sphere... these have been created to be as simple as possible, when no other 3D asses is available. The "default" level has been chosen to be 1200 vertices for the complete fixture. A complete fixture "typically" being a moving head and this has been providing good guidance in our experience, as it makes people aware of the properties of 3D models. So for base/yoke/head fixture, this ends up being some 400 vertices per model. If the fixture has many lenses, these would typically be referenced, but when preparing our 3D assets, if we have a way to test in real software, we look at what the fixture looks like and ensure good first hand experience. The low level of detail allows to provide even simpler models with more decimation, i am not sure if any software is using this at the moment. The high level of detail is there to allow unlimited details to be expressed. Kind regards Petr
  27. Hello, you cannot link the Wheel from the "fast shortcut" of the Channel Function, but you can add it if you open the full modal dialog editing the channel function properties: This then allows you to select gobos for each channel set: Depending on the use case, you will have to test if the software of your choice visualizes ColorMacro... Hope this helps Cheers Petr
  1. Load more activity
