Who's Online 0 Members, 0 Anonymous, 2 Guests (See full list)
Darren joined the community
Cruze_Volux joined the community
Petr Vanek - Robe started following GDTF and MVR Events at PL&S 2024 , GDTF Builder Update April 2024 and Saving errors
I'm testing a build fixture Brother_Brother_and_Sons@Compact_Fresnel_Light_-_Wide_-_Single_Color_5600K@REV0.gdtf in MA3. The fixture is Single Color, but on the Color tab the values for R, G and B show up(they don't work). How can I make them disappear, or I did something wrong when I created the fixture?
