mgeasey@clearallvisualsllc.com Posted January 10, 2020 Posted January 10, 2020 Hey Y'all! This might seem like crazy talk, but, is it an idea to have the 3D model of such fixtures that support it, change the pixel orientation as they do in real life, current work around would be the reference items XYZ mapped accordingly, but, maybe an option to switch the model out? I dunno, but with how complicated the fixtures are getting today and giving the operators the ability to change the pixel orientations, it would be cool to figure out a way for the 3D model to follow suit. Thoughts? Cheers! MattG
dmueller Posted January 17, 2020 Posted January 17, 2020 Hi MattG, could you tell me a fixture where I could take a look at it? Cheers, Daniel
Rex_P Posted January 17, 2020 Posted January 17, 2020 Don't ColorForce series of fixtures have a Left--Right or Right--Left internal mode to 'swap' the 'patch' of the fixtures? Would that be an example of such a request?
mgeasey@clearallvisualsllc.com Posted January 19, 2020 Author Posted January 19, 2020 Howdy Howdy! Yea, so, fixtures such as the JDC-1, X4 Bar, Colorforce Series, there's a bunch of others as well Thanks Rex!
dmueller Posted January 20, 2020 Posted January 20, 2020 Ok, now I understand what you mean. It is not possible to change the pixel orientation dynamically at the moment. I have created a Feature Request also for this topic.
NRG Sille Posted January 22, 2020 Posted January 22, 2020 The solution I used for MA2 profiles, like the TurboRay was a rotate parameter with zero fade time as a parent for the instances. This does not work for all constallations, but it was the best workaround ?
Rex_P Posted January 22, 2020 Posted January 22, 2020 (edited) re-defineArray(); re-defineMatrix(); re-definePatch(); ...something, something, lol. Edited January 22, 2020 by David "Rex" Whalen
jlang Posted May 29 Posted May 29 Bringing this back to life. How to display the pixel orientation in a visualizer based on a control channel change. Has this been implemented or worked around yet?
Petr Vanek - Robe Posted May 29 Posted May 29 As control channel change is not persisting on DMX, one cannot use the Mode Dependencies structure for this, but a new geometrical tree with new pixel layout can be created to accommodate it, the device would need to be re-patched.
